26 Апреля 2024, 17:05:44
| | |-+  Катки. Размеры, диски, резина, калькуляторы величин
Автор Тема: Катки. Размеры, диски, резина, калькуляторы величин  (Прочитано 12838 раз)
« : 05 Сентября 2012, 06:03:05 »
108.0mm = 4.25"
114.3mm = 4.50"
120.7mm = 4.75"
127.0mm = 5.00"
139.7mm = 5.50"
225/85R 14 = 29 X 9.00 X 14
265/70R 17 = 32 X 11.50 X 17
215/75R 15 = 28 X 8.50 X 15
275/70R 17 = 32.50 X 11.00 X 17
215/85R 15 = 29 X 8.50 X 15
285/70R 17 = 33 X 11.50 X 17
225/75R 15 = 28 X 9 X 15
295/70R 17 = 33 X 12.0 X 17
235/75R 15 = 29 X 9 X 15
305/70R 17 = 34 X 12.00 X 17
325/60R 15 = 31 X 12.50 X 15
315/70R 17 = 34.50 X 12 X 17
Q78-15 = 35.50 X 11.00 X 15
255/55R 18 = 29 X 10.50 X 18
215/70R 16 = 28 X 8.50 X 16
285/60R 18 = 32 X 11 X 18
225/70R 16 = 28.50 X 9 X 16
285/65R 18 = 33 X 11.50 X 18
225/75R 16 = 30 X 9 X 16
325/60R 18 = 33 X 13 X 18
235/70R 16 = 29 X 9.50 X 16
325/65R 18 = 35 X 13 X 18
235/85R 16 = 32 X 9.50 X 16
355/65R 18 = 37 X 14 X 18
245/70R 16 = 30 X 10 X 16
305/50R 20 = 32 X 12.50 X 20
245/75R 16 = 31 X 10 X 16
305/55R 20 = 33 X 12.50 X 20
255/70R 16 = 30 X 10.50 X 16
325/60R 20 = 35 X 13.00 X 20
255/85R 16 = 33 X 10.50 X 16
355/60R20 = 36.50 X 14.00 X 20
265/70R 16 = 31 X 10.50 X 16
325/50R22 = 35 X 13.00 X 22
265/75R 16 = 32 X 10.50 X 16
265/80R 16 = 32.50 X 10.00 X 16
275/70R 16 = 31.50 X 11 X 16
285/75R 16 = 33 X 11.50 X 16
295/75R 16 = 33.50 X 12 X 16
305/70R 16 = 33 X 12.50 X 16
305/85R 16 = 36 X 11.50 X 16
315/75R 16 = 35 X 12.50 X 16
325/70R 16 = 34 X 13 X 16
325/80R 16 = 37 X 13 X 16
365/65R 16 = 35 X 14.50 X 16
Q78-16 = 35.50 X 11.00 X 16
тут диски, основном на после 2000 года
http://www.autos.lt/index.php?subj=readtopic&id=16
шинный калькулятор
http://jeep.avtograd.ru/Tires/tiresize.htm
http://www.dakota-truck.net/TIRECALC/tirecalc.html
http://www.rimsntires.com/specs.jsp
Метрический калькулятор
US and Great Britain use Avoirdupois weight measurement system for all goods except of noble metals, gems, and drugs.
http://www.usa.ru/us2mtric1.html
Перевод/конвертация галлонов в литры (галлон (амер.) в литры) и литров в галлоны
http://bilet.pp.ru/perevod_gallon_v_litry.php
Интерактивный конвертер величин (тут в принципе все)
http://www.ru.convert-me.com/ru/
Маркировка шин для внедорожников
HP (High Performance)
Высокоскоростные шины для внедорожников премиум-класса.
Предназначены для эксплуатации на твердых дорожных покрытиях.
Как правило, шины с маркировкой HP имеют асимметричный рисунок протектора.
Шины имеют скоростные индексы не менее H ( 210 км/час ).
HT, H/T, HT+ (Half Terrain)
Шины могут эксплуатироваться на внедорожниках любого класса.
Шины предназначены для использования как на твердых дорожных покрытиях, так и на грунтовых дорогах.
Как правило, шины с маркировкой HT имеют классический дорожный рисунок протектора.
Шины имеют скоростные индексы не менее S ( 180 км/час ).
AT, A/T, AT+ (All Terrain)
Шины предназначены для использования как на твердых дорожных покрытиях, так и на бездорожье.
Протектор шин с маркировкой AT имеет грубый рисунок с крупной нарезкой шашек и широкими дренажными канавками.
Шины имеют скоростные индексы не менее Q ( 160 км/час ).
MT, M/T, MT+ (Mud Terrain)
Шины рекомендуются для установки на внедорожниках, специально подготовленных для использования в условиях бездорожья.
Шины предназначены для эксплуатации на песчаных, глинистых и топких грунтах и в условиях горной местности.
Как правило, шины с маркировкой МT имеют "тракторный" рисунок протектора и дополнительную защиту боковины от порезов.
Типоразмеры шин
ПРИМЕР: 195/65 R15 91T
195 — это ширина шины в мм.
65 — Пропорциональность, т.е. отношение высоты профиля к ширине. В нашем случае оно равно 65%. Проще говоря, при одинаковой ширине, чем больше этот показатель, тем шина будет выше и наоборот. Обычно эту величину называют просто — «профиль».
R — означает шину с радиальным кордом (по сути, сейчас почти все шины делаются именно так).
15 — диаметр колеса (диска) в дюймах.
T — индекс скорости. Чем он больше, тем с большей скоростью вы можете ездить на данной шине, (в нашем случае ИС — Т — до 190 км/ч). (Таблица расшифровки индексов скорости).
91 — индекс нагрузки. Это уровень предельно-допустимой нагрузки на колесо. Для легковых автомобилей он обычно делается с запасом и при выборе шин не является решающим значением, (в нашем случае ИН — 91 — 615 кг.). (Таблица расшифровки индексов нагрузки) .
Сезонность шины
Для какого сезона предназначена данная резина Вы можете узнать также на боковине шины):
M+S — Mud + Snow: грязь плюс снег
As — All Season : всесезонная
Aw — Any Weather: Любая погода
Rain, Water, Aqua, Aquatred или Aquacontact (или пиктограмма «зонтик») — означает, что эти шины специально спроектированы для дождливой погоды и имеют высокую степень защиты от эффекта аквапланирования.
Пиктограмма * (снежинка) — шина предназначена для использования её в суровых зимних условиях.
Если на боковине шины нет этих обозначений, то эта шина предназначена для использования её только в летних условиях.
Обозначения ошиповки шины
AD - шина ошипована аллюминиевым шипом.
SD - шина ошипована шипом с твердосплавным сердечником.
DD - шина ошипована шипом с прямоугольным серднчником с алмазной гранью.
OD - шина ошипована шипом с овальным сердечником.
MD - шина ошипована пластиковым шипом с твердосплавным сердечником.
Дополнительные обозначения шин
Rotation — направленная шина, направление вращения которой указано дополнительной стрелкой на боковине шины.
Outside и Inside (или Side Facing Out и Side Facing Inwards) — ассиметричные шины, при установке которых нужно строго соблюдать правило установки шины на диск. Надпись Outside (наружная сторона) должна быть с наружной стороны автомобиля, а Inside (внутренняя сторона) — с внутренней.
Left или Right — означает, что шины этой модели бывают левые и правые. При их установке нужно строго соблюдать правило установки шины на автомобиль, левые только слева, а правые, соответственно, только справа.
Tubeless — бескамерная шина. Если этой надписи нет, то шина может использоваться только с камерой.
Tube Type — шина должна эксплуатироваться с камерой.
MAX PRESSURE — максимально допустимое давление в шине, в кПа.
Vmax - допустимая скорость более 360.
SSR - система аварийной защиты шины при потере давления.
М3 - шины разработанные для BMW.
N1, N2, N3 - шины разработанные для Porche.
MO - шины разработанные для Mercedes-Benz.
ML - шины с защитой обода диска, для Mercedes-Benz или Audi.
MFS (Maximum Flange Shield) - максимальная защита закраины диска.
С, LT, Reinf, RF - усиленная шина.
FR (Flange Rotector) - шина с защитой обода диска.
LT (Light Truck) - шины для легких грузовиков, микроавтобусов, малых коммерческих автомобилей, тяжелых вне дорожников.
XL (eXtra Load) - шина с повышеной нагрузкой.
Е17 - соответствие Европейским стандартам.
DOT - соответствие стандартам США.
PLIES: TREAD - состав слоя протектора шины.
SIDEWALL - состав слоя боковины шины.
MAX LOAD - максимальная нагрузка, кг / английские фунты.
MAX PRESSURE - максимальное внутреннее давление в шине, КПа.
DA (штамп) - незначительные производственные дефекты не препятствующие нормальной эксплуатации автошины.
TWI D - указатель индикатора износа проектора шины.
MADE IN... - страна производитель шины.
Американское обозначение типоразмера.
Существуют два типа маркировки американских шин.
Первая очень похожа на европейскую, только перед типоразмером ставится буквы «P» (Passanger — для легкового автомобиля) или «LT» (Light Truck — лёгкий грузовик). Например: P 195/60 R 14 или LT 235/75 R 15.
И другая маркировка, которая принципиально отличается от европейской.
Например: 31х10.5 R15
31 — внешний диаметр шины в дюймах.
10.5 — ширина шины в дюймах.
R — шина радиальной конструкции.
15 — внутренний диаметр шины в дюймах.
тут сделал Refmanual_MODEL.pdf
http://trucks-club.3dn.ru/_fr/1/Refmanual_MODEL.pdf
тут Каталог МТ-шной резины, цены древние, но описания читабельные...
http://www.suzukovod.ru/showthread.php?t=4776
« Последнее редактирование: 17 Марта 2013, 19:28:46 от Fonik » Записан
